TJ master cylinder with HP44/9" combo?
VortecJeep
Powered by Uranium-235
Concord, NC
I'm still collecting my parts for the TJ build. Will the stock TJ master cylinder be sufficient with HP44 and 9" from a late 70s Bronco or will I need to swap the master cylinder for something else?
Did the HP44\9" swap on a 98 XJ (don't know if its the same MC)and it stops way better than before, were running drums in the rear though. I'd say if you were going 3\4 ton and up you would want to change it out.
Landon
