HANO
meh.
- Sep 16, 2006
- Myrtle Beach
2001 TJ 4.0 Automatic 50,000 Miles
Power using add-ons.... Winch, Rocklights w/ relay, ARB compressor Pump.
I have a yellow top optima that when fully charged, will be drained to the point of barely turning over in roughly 5-7 days. Using a test light, I have found a sort of rhythmic parasitic draw that flashes bright then dim and so on and so forth when using the test light.
I have pulled every fuse under the dash to no-avail, however in the fuse distribution center under the hood, the fuse that controls much of the electrical activity to the dash board and surronding area, when pulled cuts out the rhythmic draw, however the odometer will then flash no fuse.
All that to say this, I have disconnected every add-on, one at a time with no luck, checked underneath the dash again with no luck. Can I install a battery disconnect switch such as the ones I have used in the past for dirt trackcars (Moroso) or a general marine use disconnect? I care nothing about the time being right or radio stations being saved, I do believe however that it will put the computer into a learning mode each time I completely disconnect the battery,but will it harm any other device and or the computer?
The rig is towed to the trails, but occasionally driven during the week as well. I know the switch is a band-aid, but I have had no luck finding the problem and I am getting tired of pulling the battery charger out every week when Im ready to run down to the beach or getting ready for the trail.
Whats the word, is the switch harmful to a newer computer system, or a easy soulution to a aggravating problem..?
J.R.
J.R.
