- Mar 13, 2005
- Raleigh, NC
Our TJ has a 2.5" spring lift... all stock links and mounts otherwise. I'm getting ready to make a set of lowers for it, but I got to thinking that... while not *terrible*... it still does the typical TJ torque jacking/pick the left front tire thing, especially if the right rear tire is drooped out.
So... I think that a typical long arm setup would be more trouble than it would be worth. It would be a pain to work the clearances out, and probably makes the belly break-over worse. It just doesnt have enough spring under it.
What's the hot ticket? Can I add a few inches to the lowers and improve the situation? Or does it all need to change? Triangulate the uppers, move the axle brackets, etc. Basically trying to figure out if there are some minor changes I could make now that would significantly improve the performance without rebuilding *everything*.
I looked around for the stock measurements, but haven't found anything yet.
