TJ wiper motor wiring
XJsavage
CounterCulture
Lyle's Ford SC
Anyone have a wiring diagram for a 5-wire TJ windshield wiper motor? Google is no good and i cant find it in any of my files. There's 5 small gauge wires coming from the motor (red, black, green, grey/white and pink). I have a good idea which is power and ground but the others I would assume to be tied into a fluid pump, multi speed switch...? I don't want to burn it up finding out I was wrong. Thanks.
What year exactly is the jeep does it have intermittent wipers (delay) or just Hi/Lo. Also, are you running a stock switch or trying to change it to toggles. I'll see what I can come up with at work.
1999, I'd assume hi/lo no stock anything and my goal is to have just a toggle for multi speed use with a universal dash mount wiper switch.
I couldn't save the picture of the wiring diagram so if you still need it I'll have to try to print it then scan it to attach, but here's how its wired up:
The pink/black wire is ignition hot from the fuse, the black wire is the ground. The red/yellow wire is hot in high, the brown/white is hot in low speed. That should get them working but possibly not parking on their own. The dark green/yellow wire is hooked to the brown/white when the switch is turned off. That is the wire that should make the wipers park on their own when you switch it off.
If you want me to try to get the diagram printed and scanned just let me know
Thank you very much sir!! That tells me everything I need to know.
