Josh C
- Mar 21, 2005
- Wilmington NC
Everything works except when you turn the key the engine won't turn over. When you hit the air locker switch, it only stays on while you hold it down. The dash lights indicating engagement don't come one and it the compressor turns off and on rappidly while holding down the switch. The fuse for everything that comes on when the ignition comes on had to be replaced tonight due to getting blown. I'm thinking my ecm may have gone in the process due to some wires getting crossed or either the automatic shut down relay. I swapped the starter relay with another one under the hood but it still did the same thing. Any suggestions?
