TMR 14 Bolt Shave Kits In Stock - $149.95 Shipped!
Daves Offroad Supply
Offroad Parts & Custom Fabrication
Nazareth, PA
Daves Offroad Supply has the TMR 14 Bolt Shave Kit.....the 15 Bolt Conversion!
They are in stock ready to ship!
They will be $149.95/shipped to the Lower 48 States!
Order them HERE and use promo code "tmr15free"!
You've demanded it and here it is! The TMR Customs 14 Bolt Shave Kit, also known as the TMR Customs 15 Bolt Conversion! TMR spent 6 months testing this kit in the worst conditions and we haven't been able to hurt it.
TMR listened to you the customer when building this kit, and since so many of you already have an aftermarket cover all you wanted was the bottom shave plates. The advantage of our shave kit is that it can be used with ANY aftermarket fabricated diff cover.
TMR starts with thicker plates than our competitors and leave more material where it matters - directly under the ring gear. The extra material we leave eliminates fear of warping the Cap Plate when welding, and it gives you the confidence to relentlessly beat on your diff without fear of breakage!
Ring gear machining is required - the reason TMR does it this way is simple - if you are going to all the effort of shaving your diff you might as well do it once and do it right. Our TMR Customs 15 Bolt Conversion takes your 14 Bolt to near Dana 44 clearance!
Kit includes the following:
-Detailed Instruction Manual
-All required Stainless Steel Cap Screw Fasteners
-1 x Differential Cap Plate
-1 x Differential Cover Cap Plate
-1 x TMR 15 BOLT Conversion Logo
***RING GEAR MACHINING REQUIRED, DIFFERENTIAL COVER NOT INCLUDED!***
ai1320.photobucket.com_albums_u524_DavesOffroadSupply_TMR_15_b874a38e80ac98844f98278e0653ca4fd.jpg
ai1320.photobucket.com_albums_u524_DavesOffroadSupply_TMR_15_b35da35d2351c47f707ffc5bcdcf25d29.jpg
ai1320.photobucket.com_albums_u524_DavesOffroadSupply_TMR_15_b36c04acf613dfdae93809ccf543378b1.jpg
ai1320.photobucket.com_albums_u524_DavesOffroadSupply_TMR_blueprint_97_zps775c7d94.jpg
ai1320.photobucket.com_albums_u524_DavesOffroadSupply_TMR_15_b2c9a271df4759dd23f9f9e4923ce1d03.jpg
Contact Info
Email: dave@davesoffroadsupply.com
Phone: 484-554-3584
