BUCKETOBOLTS
Member
- May 4, 2005
- Faith, NC
OK I finished up swapping my NP435 for a C4. I started out pulling the NP to send the main shaft out to have it shortened and resplined for a 203 doubler. So I had to have some sort of back up plan so my rig would not be down for too long. I built a C4 for duty in my Early Bronco. A pretty straight forward swap.
Now for the I'm not so certain deal. I let a buddy talk me into a step up from stock convertor. The stall is supposed to be from 1600-1800. And when you flash it from an idle it does about 1800-2000 on my cheapo tach. My peev is that when I cruise at 2200 or so and stomp the throttle (without the detent connected) the convertor will flash to 3K. It may just be this brand of convertor. I believe it is going to be too loose to work on the trail. My engine makes a lot of torque down low and I think it is blowing threw the convertor.
