Chris_Keziah
Joe Dirt @ Rev Limit Fab
- Dec 1, 2010
- Winston-Salem
Good work on tow rig. Any thoughts of puttin a fifth wheel on it?
Yup that break in lube is crucial. I started using it plus diesel oil to get the phosphates and zinc. Sounds like you got it going on!Not worried about the holley. It's a tinkerers carb. And I'm a tinkerer. I've been putting holley's on stuff since the mid 80's I'm very comfortable with them.
Cam break-in:
pre oil the motor with a drill
Pour crane break in lube
prime the carb by filling in the primary fuel bowl
when it starts up run it between 2000 and 3000 rpm's. never keeping it steady
Cams are splash lubed so this will ensure it is lubed.
Try to make sure the timing it set from the get go.
This is done to minimize the cranking. You want it to fire as quick as possible.
You'll be fine with a 24 tooth, how much bigger of a tire are you going with?
Edit: sorry I completly mis read your question. I found this place that has gears. Click Here Looks like they only have a 23 and 25 though.
