toyota 22r cam upgrade
**89mightymax**
taylorsville
This is to anyone that has a bit of experience in building 22r motors.(more than stock) I'm getting a comp cams Magnum series cam for my 85' it has 455 lift. I talked to someone from comp cams and they said I won't need to upgrade my valve train. Anyone use this cam before?
depends on what you want out of the upgrade, like any other performance upgrade, $$$ is the stepping stone.
at minimum I would replace the rocker arms, they wear "burnish" to the cam in the first 30min of run time, installing a new cam with old rockers is a pretty good risk of wiping off the cam lobes in short order, even if you properly break in the cam.( 20-30 min sustained 2000rpm, keep the oil flowing over lobes and followers, lobe and follower should "burnish" to each other, and work harden.
I've done cheap, medium and expensive cam upgrades, cheap one lasted about 15k miles before 2 lobes were wiped off the cam ( reused the original rockers ) , next was new cam, new rockers and valve springs, along with a 3angle valve job, much better performance, over 100k before I sold it, the expensive was new head ( with performance valve springs ) cam, rocker towers, rocker shafts and new rocker arms/cam followers, adjustable cam timing gear (degreed) . ran well, but could have been better, sizing the towers to center the followers on the lobes would have helped a bit, but I didn't have time or the extra cash.
the last two cams swaps in 22re were LC Engineering, worked well with OEM fuel injection and a mildly modded air flow meter. LC Engineering long tube header, 2.5" cat 2.25" pipe and flow master 50 series muffler. Ran well, sounded good. YMMV
Well I "was" going to reuse the original rockers... I guess thats a bad idea now. You think stock springs will be ok for now? I was going to wait to get a set of dual springs
valve springs have a rough life, ( watch some of the youtube vids of valve train in action )
can it work?, yes, will it work ? probably, for how long ? thats the unknown. OEM Toyota stuff is pretty durable, but stuff wears and breaks.
remember, to pull the cam you need to remove the rocker towers and head bolts, so you may as well pull the head anyway to at minimum replace the head gasket. now is the time to do any head work.
rocker arms are a lot cheaper now than when I did mine, as are the gasket sets
as for "being ok for now" ask yourself, how may times do you want to do it ? if you like tearing it apart and rebuilding, sure, go for it. I got tired of "redoing" things because I cheaped out the first time. when i was younger, didn't know anyone in NC and had time, it was fun ( and expensive ) but it was all part of the ride.
