Toyota 8" Rear axle U-Bolt flip kit from RUFFSTUFF!
Dan Fredrickson
Sacramento
This kit will replace the stock U-bolt assembly in a spring under, or spring over setup with Round Bend U-bolts giving you not only more ground clearance, but also pointing the threads away from the rocks you drive over which can make them impossible to remove without cutting.
agallery.ruffstuffspecialties.com_var_resizes_New_Product_Ads_6b2cb49053b71fe0518405852d67357d.jpg
These, like all of our U-bolt kits feature 3/8” thick Top plates, each with three available holes for the center-pin, which when used with our spring perches gives you the ability to move your axle forward or backward an inch very easily.
The U bolts are a 5/8” fine thread, Grade 8 rod that we bend in house, and they all come with not only extra-thick flat washers, but also Grade 8 tall-nuts that have ~ 75% more thread engagement than a standard nut.
One thing to keep in mind is that the stock configuration mounts the shock to the original U bolt plate, which means that you will need to come up with a new way to mount the shocks to the axle.
