Toyota ARB locker?
Bigben75ford
Asheboro,NC
So I have a 94 SASed yota that just this past weekend I installed a ready to go ARB third with 5.29 gears.Well I had never messed with air lockers before but before I installed I got my air hose and shot some air in it to make sure it worked.Well after I installed it I took off down the road and when i got back saw oil all over the third.So I took the third out to visually inspect how the copper line runs and cleaned everything,fittings and all ,replaced the o-ring and put it back together.Today I took it down the road and its STILL leaking.ANyone have any ideas?looks like its coming out of the top of the fitting.
anyone?
i've never installed an ARB... but can you tell where exactly the oil is coming from? Could it be teh general seal w/ the diff or is it around the vac line into the unit?
Well its hard to tell,it looks like its coming out of the top of the fitting where the air line hooks to it which means the air seal inside could b leaking and oil coming up through the copper line but I cant tell for sure.I replaced the o-ring inside and retaped the fittings and re installed its still leaking.
did you try to use teflon tape on the fitting that is threaded in the housing?
yeah i did,took it to cperry today and he hooked me up!
I dont have my compressor or wires running to it yet,if I get my trans and t-case in by saturday im coming up to my gramps to get those wheels,if I do Ill give you a call!
