aron0128451
- Nov 17, 2010
- leland, nc
first off let me explain what ive helped create. its a 94 4runner chassis with a 93 extended cab and bobbed bed. 3.0 with the auto. and its up on 37" boggers. its got ngk plugs and wires, a performance chip, custom exhaust and a 14" electric fan. also running richmond 4.88's front and rear. now heres the issue were having. truck wont shift into overdrive. unhooked the fan and it hit overdrive, but the motor got a bit toasty. pulled the thermostat and saw it had been cut up by the previous owner. put in a 195 degree stat and hooked the fan up aand the truck over heated. installed a 180 degree stat and got the same result. now with the cut stat in it the heat and all worked great, just wouldnt go into overdrive. any ideas?
