Toyota axle gear swap question!??
Trailmaster C
Roxboro N.C.
I am gonna be swaping in 571 gears, I now have 410 will the gears just swap out? Will I need anything else??
Thanks,
Bradley C
Bearings if you are not reusing them.
And a very patient anal-retentive installer.
I refuse to jump on the 5.71's are grenades bandwagon. With a proper set up they have taken some crazy abuse.
You will definitely want some shims so you can set the pinion depth......or drop them off over at ECGS....;)
I think if you have to ask, you shouldnt be doing a gear setup. I have built most of the stuff on my rig and am still not comfortable enough to set up my own gears.
Thanks for the answers! I just wanted to know if I needed to buy any thing like a differant carrier or ect!!!!!
NO THANKS FOR THE SMART AZZ COMMENTS!
he's not being a smart ass, just stating the obvious based on you OP.
get a new diff set up kit from marlin because you will likely ruin a bearing or something else when you remove the old gears
