toyota brake help
Stuntman Autoworks
Instigator of things
Snow Camp NC 27349
I am looking for a place to buy brake fittings, preassembled hose and hard line for my samurai. I'm running toyota axles, I have found they use 10mmx1.00 fittings and is double flared.
The stock sami master cylinder I haven't been able to find the thread size on it.
I need to find a place to buy all my fittings and tubing, every place I have looked so far has fittings that use double flare and then only have tees that use bubble flare.
Does anyone know that the info I have so far is right and can anyone help with a good place to buy all the supplies at?
Thanks in advance, Ive looked and searched for 2 days and haven't found everything I need yet and need some help.
Napa had everything I needed to swap overvto chevy stuff.. I'd start there they have lengths to hard line for cheap
Sent from my SCH-I535 using Tapatalk
The one here in Salisbury had a pull out cabinet with every size adapter you could think of.
As stated above you may or may not have to upgrade the master cylinder to get the pedal back stock feel. I had to with one tons but I've never done a Sami yota rig. So you might get lucky with just running lines and to what u have.
Yeah several guys that I talked to said the sami master would do good with the yota brakes so we will see. I ordered alot of stuff from napa last night online and they called and said it would be in first thing tomorrow morning. Thanks for all the help, I didn't think a regular parts store would have all those loose fittings and such.
I got all fittings and hard line from carquest out of the catalog and had a local place make the soft lines
Does ECGS make hoses ?
I sent an email to Chase to ask when I should stop by to do them....
No answer....
Do he answer his own email or do some of you other folks answer them?
And i was going to give him a hydraulic cylinder, double ended (B/N) from Trail Gear
Yah well wait on that......
I have a nice clutch hose that he (Chase) made with the ends and all that...Works like a dream....
I just assume that he was getting out of the business....
Nick, maybe i can contact you ?
Call today Mike, talk to Stephen, Curtis or Chase. Chase is in the shop today with us monkeys, Stephen or Curtis could get you straight. We'll be closing around 4-430 today also.
And we can make any brake/clutch and air lines(for air lockers and such), hard or soft.
go to the junkyard and find you a Subaru master cylinder. Don't remember what model but it looks just like a sammi master but its 1-1/16" bore vs. 7/8" bolts right on and lines screw in. you will have to adjust push rod length in booster. it has a screw on yellow lid and only two ports just like a sammi. some have 4 ports, you don't want that one. Oh and brake fitting size is 10mm but i can't remember if its 1.0 or 1.25 pitch
