Toyota cut and turn axle
For a show - you are on the right track. For snow - it will straight up suck mainly because of the tires. Not because they are 44s, just no siping. 33" TSLs suck in snow. Mud holes - keep well clear of those. Mud breaks as much stuff as rocks.
I wouldnt spend the $$$ on rotating the knuckle balls then. Just make something that looks like a driveshaft and remember not to use 4x4. With that much lift, it will be hard to make a driveshaft work at those angles even if you rotated the knuckle balls.
You can get a 6' stick of 2.5" chain link fence post that is powder coated black at Lowes for around 15 bucks. Cut that to fit and just weld it in to make your shaft. It is probably as thick as an OEM shaft anyways.
is there a transfer case I can install like you see on mud trucks??? one of the Rockwell transfer cases? The ones that drop the driveline down to where its parallel to the 3rd on the axle
