Toyota diff. advice
mommucked
Endeavoring to persevere
Rural Apex n.c.
My rear pinion seal is leaking bad, closer inspection shows some slight slop in the pinion trying to rock it up and down holding the driveshaft. Can I replace the seal and re-tighten to fix or will I need a new crush sleeve or more parts/repair to remedy this? It has 150K on it.
Depending on the year it shouldn't have a crush sleeve it will have a solid spacer. I'd just replace the seal and run with it.
Sent from my mobile Toyota base using Tapatalk
what years would that be
Honestly I can't remember, all the ones I've seen have been solid spacer but I have heard there are crush sleeve ones.
Thanks for the replies, I found my manual and the spacer on 79-87 is deformable during preload/tourqing the nut back on and may need to be replaced it during the procees, won't know till I try I guess. I also evedently need an inchpound torquewrench so I might just get somone to fix it for me instead.
I wish..........I can feel and see the shield over the snout ( moving/rocking just a smidgen ) while pulling hard up/down on the driveshaft and have had some vibration at various speeds/power before the leak started. I think the pinion bearing is shot?? I have 2" springs, and 3" tapered blocks I installed backwards I think, (short side of taper to the front), and the diff. is angled up steeper than the trans w a 2 u joint shaft, which I now know is not correct they should be parallel. I'm guessing the clash/strain of the ujoints and misaligned flanges has damaged the pinion bearing.:eek:ops:
Hi, I am assuming it is an 8" 3rd member either a a 4 cylinder or 6 cylinder. Do not use a crush sleeve especailly if you wheel it off road. Install a solid spacer, it is only a few bucks more and will give you much more peace of mind.
yeah go with a solid spacer new seal new bearings
