I've seen rigs w triple cases. Kinda overkill IMHO.
There is some footage out there of a yota with triple cases and tons on the Rubicon.
Is this the one you are thinking about??
Personal loan? Stay FAR away from those!Haven't found the trans issue either. Might get a loan and get a new marlin tranny.
I bet after finding a case, buying the adapters, having them installed, and new shafts made he is at $1500-1800Advice #1, try very hard not to finance hobbies.
#2, if two reputable shops have said that cutting/rotating the knuckles is the best option for you, it probably is. I know $1000 sounds like a lot, but you will likely have over 60-70% of that in dual cases.
Will take a new shaft or a new flange for the 1 ton either way its money...IF moving the case back 6.5" is enough to lessen the angle enough for a standard shaft to work!!!!
