Ive got high steer on my 95 Toyota pickup. is there a way to raise my tie rod to give me more clearance for a thicker leaf pack? Or a way to drop the tie rod below the springs like the stock setup?
4x4labs has custom arms you can order so that the tie rod can clear. Depending on how your suspension is setup, you might be better off doing a cut and turn on the knuckles so that you have the correct steering angles and driveline angle.
