hurt4x4
- Sep 12, 2012
- Greensboro
I have a rattling noise coming from what sounds to be my transfer case.
It only makes this noise at speed 20+mph during a nuteral coast with the clutch depressed, in nuteral clutch released or at a nuteral rpm while driving. No noise while under acceleration or coasting in gear. It does seem to be related to speed.
vehicle is an 82 pickup, w56, single rf1a t-case with 4.70 gears .The noise seamed to get worse after the w56 was swapped in, but was there before the swap.
So far I have checked u joints front and rear, the front shaft is kind of sloppy so pulled that, checked pinion nut and flange nuts on the tcase to be sure they are tight. I'm not really sure what else to look for at this point without pulling the t-case.
Anyone have any suggestions or any ideas on what could be causing this?
