Toyota Samurai Buggy Project Part Out
wheelNC94GC
Chesnee SC
$1800 FJ80 axles - Rear is FF with 4/.10 and spool, Front is HP 4.10 with lunchbox locker and hellfire knuckles and high steer arms. Stock shafts in f/r.
$500 PSC double ended ram, orbital, reservoir, tc pump with PSC pulley
$300 2 Corbeau seats
$1800 Toyota dual cases, Front 2.28, rear 4.7, triple shifter, rear case mount bracket, front case crossmember mount
$700 w56 trans with RingR adapter and new clutch included for 8V tracker
$350 propane kit with 1 tank, I think there are enough parts for almost 2 kits and some 22R mixer parts
$150 electric fan and Al radiator
$250 turbo manifold, ko3 turbo, wastgates (internal that came with turbo and external wastegate kit wasnt sure which route I was going to go)
$300 8v engine short block
$250 MSD 6AL box with blaster coil, has 7k rev limiter in it, can be changed to other rpm limits
$100 Hedman 8v header for 1.3/1.6 samurai/tracker
$200 heims/links 7/8" heims on the lwoer links and 3/4 on the uppers. Has all hardware with it.
$800 2-14" & 2 -16" FOA 2" remote res dual rate coilovers w limit straps and coils
$1000 Samurai body, setup for 1.6 tracker motor and Toyota driveline. Have title
Please text me if you have questions or would like more info, prices are OBO. Everything is located in Chesnee SC. My cell is eight two 8 two 43 five 4 zero five - Brandon.
