toyota solid axle question
yota4me
Raleigh
so Im finally rebuilding the axle that I tore apart over a year ago. I do not recall how many shims between the knuckle and steering arm and the knuckle and bearing cap. Can I just make all four sides the same or is there some way to measure? Is this a serious problem?
Thanks
Unless someone here knows a trick...you will have to put it together and check perload with a fish scale.
This will help too:
http://www.lukemiller.org/toys/1985_toyota_4wd_front_axle_FSM.pdf
I ignore all the SST stuff and just put them together and pull on the steering arm with a fish scale...specs are in that PDF.
Needs to be tighter= less shims.
Looser(easier to pull) more shims.
