toyota spring question
dairyman
Kings Mountain nc
Im sas my truck and it currently has a 5" lift on it, I was wanting to run rears up front but i cant figure out which rear springs would equal the lift in the back. or would it be better to go with front springs from trailgear or somthing?
If you have 5" springs front and rear, and it matches, why change it? The whole point of RUF is to not have to pay money for springs. You'll never get anywhere close to 5" out of a set of rears unless you add more arched leaves to stiffen it up.
Run RUF and add in a few leaves, then make your rear pack hybrid also. Is your rear lift a spring lift or is it blocks?
i took the two overload springs out of mine and replaced em with 1 AAL spring that is for 3 inch lift. i wud guess it is around 5-6 inch lift now with 4 leaves total. my other truck has a superlift 4'' kit and these hybrids are way more arched. clearing 38s
less lift...more cut off wheel
