Toyota steering box rebuild question
Van-go
Not an old man
Greensboro
So I’m rebuilding my steering box and just had a question because I’m finding conflicting things.
The kit I got comes with two O-rings and two Teflon rings shown as number 17 and 18.
when I took apart the box there was no O ring.
should I put one back on if there wasn’t one there before?
O ring would sit under the Teflon ring. Like it does on the piston. 10 & 9
anyone done this before?
Similar but not directly related:
Hydraulic cylinders, it's common to have a "backup" rubber o ring under a Teflon "u" seal.
I'd reassemble it the way it came apart unless there was signs of there being a o ring and Teflon previously, or there may have been extra parts, or it was redesigned to prevent a design fail with the seal pair.
I tried to put the O-ring under it but it would not seat all the way down when I tried to put the Teflon over top of it. There was definitely not an O-ring before but it’s weird that the kit would come with those seals and show a diagram of them going in.
The new teflon seal should have different dimensions than the current (OEM) teflon seal if it was meant to be used with an additional O-ring. You can't just squeeze an extra O-ring behind another seal into a spot that wasn't designed to have an O-ring. I'm not familiar with that steering box at all, but seal design is seal design.
Like I said, if it did not originally have a seal, don't try to add one. They may include one for variations in different models to cover more than one application in a package - think carb kit.
Put it together. We’ll see if it leaks. Got to get a new pressure line made cause I put a different pump in. Then we can test it.
All the jeep boxes I have ported and rebuilt, I put back together like it came apart and still had extra seals.
So the input shaft is only turning 2 turns lock to lock. Before it was like 4 or 5... any idea what I did wrong?
edit: I’m stupid.
Didn’t have the teeth lined up inside.
The kit probably serves multiple models. May be one with an o ring, and yours isn't it.
is that a land cruiser box ? I just tore one down yesterday to port I haven't removed the teflon orings I can let you know how it comes apart I know the one im working on has never been opened up before I did
It was a 86/87 ifs box
