bannerp
- Dec 4, 2011
- Newland NC
I have a customers 86 DX pickup 2wd 22re auto. Truck runs rough, searches for idle speed and has a misfire up until 2k rpm. I have checked for vaccum leaks using a smoke machine, cleaned the egr, checked the cap and rotor plug wires and replaced the plugs. Old plugs were not fuel fouled but covered in carbon as well as the 02 sensor. Ran new pcm grounds direct to battery. What typically would cause this type of problem? Bad MAF? I am at a loss and have no way to check codes because the battery was disconnected. ANY HELP/ ADVISE would be great!
