- Mar 24, 2005
- Stanley, NC
I've got a early 90s New Holland L555 skid steer with a Kubota v1902 diesel. It started acting like it was running out of fuel, and it was low, so I filled it up. It was still running, just not 100%. Then when I cranked it up last week, it started up fine, idled a few seconds then cut off. I repeated this cycle at least 10 times with the same results.
Seemed like it was starving for fuel, so I replaced the inline filter (cut it open, it was TERRIBLY dirty), and based on that replaced the canister filter on the engine, but it looked fine. Opened up the bleed, waited for the electric pump to prime, then started it back up. Same deal, it would run fine for a few seconds, then die out.
I did discover that the longer I left the key on before cranking, the longer it would run. No major correlation, but 5 seconds of key on equaled 2 seconds of run, and 2 minutes of key on equaled maybe 15 seconds of run at lower throttle. It will even sit and idle, but dies out if you come off of idle very much. It will crank and run at wide openish for a few seconds too, but runs out of fuel quicker.
The configuration is fuel tank>inline filter>inline electric pump>canister filter>injection pump. A rebuilt injection pump is about $500, a new electric pump from the dealer is $150, and a generic pump on eBay is $30. When I primed it, it took forever (15-20 minutes) for the electric pump to fill the 3" diameter 3" tall canister filter, and it barely puts out a trickle with the line loose. I'm thinking that the electric pump is toast, and it makes enough pressure to feed the injection pump if you let it build up with the key on, but it can't sustain it.
What says the wisdom of NC4x4?
