hadfield4wd
- May 21, 2010
- Roanoke, VA
I bought this. A used travel trailer frame of unknown age. No its not mobile home axles so don’t worry (even though there is nothing wrong with them). These are old demountable rims.
I got a travel permit and borrowed some magnetic lights and drove it 3 hours home.
Plans will be a deckover as it’s too narrow and I’ll lengthen it so I can fit both my xj and the kids buggy.
It sat in the back yard for several months.
As I started measuring and not only was the trailer frame bent, but the axles were welded on crooked. So I started by straighting the frame. This was actually kind of easy.
Hooked the winch up and pulled it a little, let off then measured and kept doing this until it came out straight.
I picked up some used steel from a friend and bought some new. I welded the 3.5x3.5 to the sides to add the width and braced it underneath with 4” channel.
This is also how I lengthened it. The deck is just shy of 22’. The box tube sticks up 1 ½” in so when the wood is put down it will be flush with the top.
