Trailer springs
Discussion in 'Tow Rigs and Trailers' started by neptco19, Feb 7, 2006.
  1. neptco19
    neptco19 Well-Known Member
    Apr 5, 2005
    Athens, GA
    Got this trailer a couple weeks ago and need to add some springs..Trailer has 2 3500lb axles. So will 4 2000lb springs be enough or do I need stronger ones?? Also is there anyone who has a "kit" that you could go buy and it would have everything to add them on, or will I have to piece everything together..
  2. StudNuts
    StudNuts Well-Known Member
    Mar 21, 2005
    Wendell
    youll want a little bigger of a spring. Northern tool should have a kit.
  3. Rich
    Rich Asshole at large
    Mar 17, 2005
    Central PA
    and when you get the bank, ditch the car tires for trailer tires... you'll like the difference.
  4. bigassedredjeep
    bigassedredjeep Well-Known Member
    Mar 23, 2005
    Middlesex, NC
    +1 mine is setup solid like the one above and just switching to actual trailer tires has made a huge difference in ride quality.
  5. rockcity
    rockcity everyday is a chance to get better
    Apr 10, 2005
    Greenville, NC
    Agri supply will have a whole kit. comes with shackles, u-bolts and spring plates, spring perches, spring mounts/hangers, hardware, etc.
    Rob
  6. neptco19
    Apr 5, 2005
    Athens, GA
    Think I should try this first??
  7. Rich
    Mar 17, 2005
    Central PA
    IMO, no, I'd put suspension on it first.
  8. bigassedredjeep
    Mar 23, 2005
    Middlesex, NC
    wouldn't hurt to try, but you won't be satisfied until you put a suspension under it. my trailer is not bad with the jeep loaded, but empty its a PAINFUL ride.
Share This Page
