- Sep 28, 2009
- Concord, NC
looks to be a 1 ton axle...and Id wager money that you got more than 2k between the 2 bikes and the weight of the trailer....
Am I the only one who thinks that two 4 wheelers may be to much weight for that axle and spring combo? I've never known trailers of that size to be able to carry much weight comfortably. Just what is the weight rating of that trailer?
He's plenty within limit of the trailer's 2000/2500 capacity.
Loaded up the wheelers & took a picture. The trailer is kinda sitting lower than the truck where its at in the yard, when I hauled them this past weekend when the truck & trailer were sitting on level ground everything looked level. The red atv is 520lbs. & the green is 439lbs. The trailer tires are rated 900lbs each. The axle & springs are rated either 2000 or 2500, tagged was scratched so I couldn't read it clearly. So the ATVs alone weigh 959(roughly cause those figures were dry weight from the Honda manual) I had checked the trailer's tire pressures a few weeks ago & they were good but not exact sure of their setting at this time.
