Van-go
Not an old man
- Dec 11, 2014
- Greensboro
I’m to the point where I need to buy or build trailing arms.
Planning to run a 14in coil over.
I’ve seen a bunch of different options and want to be sure I invest in something that will work and will last.
My chassis is set up for the typical 2-5/8in joint on the rear lower.
I do not want the arms to have a bend in them and lose ground clearance. I like TMR & busted knuckle’s arms.
Busted knuckle uses DOM with a Uniball inside which has a width of like 3-7/8. They used to have a different design that used a normal 2-5/8 uniball. Not sure why they changed it. They also use a 1.5in heim at the axle side to allow for more articulation.
TMR is very similar but they use a 1.25in heim so I am worried they will bind when flexed.
Been looking at Bomber fab chassis and I am not sure what they have going on. Looks small.
School me on what works and help me decide which direction to go.
BKOR Ultimate Trailing Arms
PLEASE, NOTE THE ORIGINAL YOUTUBE VIDEO SHOWS 1.75" HEIMS. THESE HAVE BEEN DISCONTINUED. This kit includes and 1.50" heims, and these have plenty of BEEF. These are the ULTIMATE Trailing arms. The MASSIVE D.O.M. housing houses a 1.25" uniball with spacers to allow a 1" bolt. Each side of the...
bustedknuckleoffroad.com
Competition Trailing Arms - DIY Kit
With over a decade of experience building DIY Trailing Arm Kits we're pleased to announce the latest generation of competition trailing arms! What makes TMR Customs Competition Trailing Arms the best kit on the market? High clearance! Bent, low clearance arms are a thing of the past! Proprietary...
www.tmrcustoms.com
