Van-go
Not an old man
- Dec 11, 2014
- Greensboro
I ended up pulling the trigger on these. He threw in 4 extra shocks that need rebuilt and knocked $500 off…
link to said video??Yeah he’s got the old style busted knuckle ones. From what I’ve seen they re-designed them since Jake made his video explaining trailing arms.
Smart moveI ended up pulling the trigger on these. He threw in 4 extra shocks that need rebuilt and knocked $500 off…![]()
Can you give me a visual of what you are saying?Enzo is correct in all information however it can be much simpler. 1.25" heims on chassis and axle side, 2.5" .250 DOM, shock tabs where you want them, backbone the arm, then fill shock mount with uhmw or teflon or something of the like that is high abrasive. Trailing arms made easy and cost effective.
Basically with a heim on each side, the arm will rotate to far and break the end of the shock off. That’s why most use some form of wobble stop or bushing on frame side to stop this. If you use two heims, it’s as simple as putting uhmw between the shock and shock mount on the arm side. This completely stops all arm rotation because the shock heim is “solid” blocking movement. It’s still moving enough inside the uhmw to not break. I have friends that have been doing trailing arms this way for years. Mine uses the 4” tmr wobble stops but I am still going to eventually do this to the shock mounts to make the wobble bushing last longer.
