Tranny is going out on the tj...What to swap with???
charliechuck
Shaw AFB
The tranny is getting pretty ugly in my TJ right now and was thinking about what to replace it with...It is a 3 spd auto...The max tire size I will ever go with will be 37s...I was just thinking of swaping it with a stock tranny or should I use this time to upgrade to something different? Thanks guys!!!
uhhh do you have an aw4 or the new auto. If you have the newer auto then you have to use that or something that came factory to please the check engine light
its a 32RE...tons of people swap 700r4s and turbo 350s...not sure what kind of adapters i would need but im sure i could find them from AA...just wondering if i should just stick with the 32RE or upgrade it...I really think i would be fine with another 32re seeing as it will only be 37s and keeping the straight 6
adapters are expensive. I would go aw4 with the stock shifter and a stand alone shifter for gear selection
AW4 won't let the check engine light go off....or atleast wouldn't in Rubi Josh's TJ
