- Mar 10, 2005
- Hooterville (24171)
It's a miracle the OE Commando crossmember (formed hat-channel with the "brim" on the bottom = anchor) in the Moss has lasted this long, but got a "wee bit" tweaked this year at GMP coming down some steps (Copperhead Road?) well above her capabilities.
Planning a new crossmember (to gain both some clearance & ability to mount a skid) for Moab, but wondering if changing it from the crossmember (rigid) with a single OE rubber mount (directly below the "potmetal" TH400>D20 adapter) to spring-eye type bushings at the frame and rigid mounting the TC to the crossmember will be OK or cause too much stress for the adapter?
Meaning, the OE bushing allows engine/tranny/TC torsional movement (twisting) all together, 3 points of contact... where moving the bushings to the frame may not give as much and exert more pressure (IMHO) to the adapter?
