transfr input shaft replacement
wild1joker
fayetteville,nc
i have a 93 w/ ax-15 manual. how difficult is it to replace the input shaft. I can only find transfer cases for automatics.mine has the short shaft and i believe all auto transfer cases have the long shaft. Any one to help?
If you've done an SYE before, this is just as "easy", but it takes longer. You'll need to take the entire case apart, so a good set of snapring pliers is a must. Other than that, take it apart, swap out the input gear/shaft, and put it back together.
