AshTraY88XJ
- Sep 9, 2009
- Raeford, NC
Transmission:AW4
Well, It started doing it about a week after I got it. Just kinda blew it though. When it's cold, it doesn't want to go in reverse at all, maybe once in a blue moon. It will go in drive and the lower gears just fine. When it gets warmed up, it will go into reverse just fine. Has plenty of fluid. I'm probably thinking im gunna have to start looking for another trans here pretty soon.
Transfer Case: NP231
Well this started happening about a month after I got it. It usually goes into 4H pretty smoothly. 4L, I have to try to engage it, put it in drive, grind it a little, and then neutral, and pop it in. going back from 4L to 4H is pretty smooth. But I'm lucky if I can get it back into 2H. I've tried the usual such as drive it in reverse a little, going down the road(sometimes this does work). Now I haven't been able to check the fluid in it because the lack of a socket or wrench big enough.
It's got 284,000 miles.
