redneckjeep87
Landscaper Extroidanaire
- Oct 10, 2007
- Woodleaf, NC
Ive got a 2000 model 5ton hudson equipment trailer that i use for work, and has regularly seen 5 ton over the last couple years. The brakes started becoming less and less effective towards the end of the year (2014) so i figured they would need replacing at some point in the near future. They still had enough to supplement braking of the truck while hauling my tractor so i wasnt too terribly worried yet.
Fast forward to last week, went to haul the trailer to get some stump grindings dug out at a clients house and didnt have any brakes when i started to leave the house so i backed up and messed with it for a little bit. Tekonsha voyager showed no connection etc. All lights work on the trailer. Didnt have time to mess with it so i took off to work. Part way there the voyager showed a very slight green led, definitly not as bright as normal, then disappeared at some point.
Yesterday started doing some troubleshooting, starting with hooking my other truck up to it just in case the controller went bad. No dice, had no connection to that one either.
When testing the blue brake signal wire on both trucks it shows constant pwr even with no pedal depressed or manual override slide over. When i found that i cut the signal wire and tested both ends, the "trailer" side had nothing and the "controller" side of the cut was still hot. Which should be a faulty controller, but i dont see the controller in two trucks going bad. I was under the impression that it shouldnt have power until brakes applied.
Is this an indicator that the magnets on my trailer brakes are beyond needing replacement or what is going on? Anyone else ever fought this issue?
Sorry for the long post, just wanted to put as much info out there as i could
