As said previsouly, the Holley TermX already has a fuel pump trigger (positive), fan1 & fan 2 triggers (both can be programmed to be positive or ground) that are already there. In other words you don't need an external temp switch to turn the fans on and off, the ECU already handles that.
You can program at what temperature they turn on/off very easily too.
For the rest, having an actual quantity of lights and accessories and their respective amp draws would help. I don't even mind making a quick wiring diagram for you if that helps but I need the extra info above. Also helps to know if you want a switch to turn all your lights on, or you want every single one separately controlled etc.
There is a big chance the BKOR unit will be cheaper than the switch pros, especially since it seem that you have more than 8 "things" to power.
If you want to splurge for the RCForce12 from switch-pros, I really believe it's the best out there for the price point, but it's definitely more expensive than the BKOR boxes.
