N4HMR
- Nov 4, 2019
- Charlotte, NC
I have a Hudson 10HHSE18X6 5 ton trailer made in 04/2006, bought it in 09/2007 along with a John Deere 250 Series II skidsteer. Pull it with a 2002 Chevy 3500 with a 12' dump bed. Likely didn't have many miles on it when I got it and I haven't added more than 500 to it since. I was told by the Hudson guy it has two Dexter 5200 lb axles.
Need to use it soon so pulled it empty to check the brakes. What I got was one wheel would lock up but none of the other three. I'm tying to pull the hubs to check on things but not having much luck by myself.
Called the Hudson tech today and got the following info. He said to pull the tire off and the drum should come off. Yeah, ok, right! He said to check the magnet top where it rubs against the inside of the drum and look for 12-15 dimples in the surface. If they are worn off smooth the magnet is supposedly shot and won't work properly. Mmmm, Ok. Didn't ask him why the magnet would be dragging on the drum but ...?
He also said that there was a screw inside that will adjust how hard the magnet will apply pressure on the shoes. He said that if I didn't like the amount of braking to re-adjust the screws. After taking the Dang drums off again - and again - and again. Gotta be a better way!
Oh, yeah, he said that if there was less than 1/8" of shoe left I need new ones.
I put a couple of lug nuts on and was prying on the back side of the drum in two places while the wife tried to tap on the nuts - didn't get anywhere. Now, Sweet Thing isn't exactly best friends with a 4 lb ball peen hammer and couldn't get a good swing on it without almost dislocating my jaw bone. After a few "Oh, I'm sorry's" we kinda gave up. Actually she gave up.
So, I'm still at square one. Can anyone give me a bit more advice on how to dislodge the drums? Like how hard I might have to smack the nuts while prying on the drum? Also, does this dimple business sound right? And why the H... does that magnet have to rub the drum? That's what the shoes are supposed to do!
And, finally, how the Heck can I gauge the braking on a wheel when four of 'em are supposed to be doing that?
ANY suggestions will be very much appreciated!
Thanks.
Fred (Frustrated Freddie!)
Thanks.
Talk to Cliff in parts. He does not care if you live or die but once you tell him your dilemma he will help you. Those brakes wear out crazy fast so that's probably your issue. The magnet deal is real and rust has a lot to do with how they work so if your trailer sits, they won't work until after you get to your destination. Drive it round and hold down the brake controller (is it working?) and wear the rust off. I totally replace mine every two years but I use them.
