@catfishblues I wish my bender was in the vertical configuration. Way more advantages to being horizontal. Also the way my bender is designed it swings both working ends in an arc. I have contrived a way to support these ends by means of a rolling cart of sorts. One man band operation is truly a dance of epic proportions.
Wasn't hard to modify. It took me a few hours to make the frame.
Any photographs?
500lb of shit in a 5 gal bucket...Any photographs?
No it's not vertical on mine. I set it up with a piece of 1.75" dom, at zero degrees start of bend with the tube set parallel to the ground, so that I would always have a true angle reading on the tubing on the bent end.It looks like I am going to just make a vertical bender out of my JD2
I don't want to reinvent anything so I'm just going to copy some ideas. I really like the press/bender combo. I'll be doing that. It looks like @mcutler has the swag tools hydro mount and @catfishblues has the base/bottom mount.
I stole this picture from the for sale section because it is at a good angle credit to mcconnell
It looks like in the above posted benders that the C angle is not vertical but I can't tell what angle it is. Any particular reason for this?
As far as A & B. Where should the hydro cylinder mount in relation to the two bolts? This is the part I don't want to guess at.
So... @mcutler @catfishblues
When they're mounted vertically, how do you account for twist? If the bender is mounted horizontally, you can true the angle finder and measure the twist in the tube. If the die is mounted vertically, you can't measure how far to the left or right it is. Or.... can you?
="mcutler, post: 1589841, member: 12432"]No it's not vertical on mine. I set it up with a piece of 1.75" dom, at zero degrees start of bend with the tube set parallel to the ground, so that I would always have a true angle reading on the tubing on the bent end.
I assume your refering to the twist in the Pro Tools vid.........honestly I call b.s. on that phenomenom. I think that "might" occur when you dies are off center from each other or the machining is not parallel for the path of the tube. I got a buddy who owns that specific bender. Its like a JD square knock off. Nothing is as near the quality and precision. It also binds badly and can be a real pain to unlock and remove the tooling.So... @mcutler @catfishblues
