Turbo gurus I need some advice
smittybronco4
clyde,nc
I got a 351w In my mustang with a forged bottom end about 9to1 compression... Alum heads victor jr intake.... Looking at. 76mm with a A1000 pump a csu carb... Anyone got some boost knowledge that can lend opinions and help to guide me some
sounds like you got everything ready to go have you got turbo,pump,or carb yet? street\strip car ? how much power do you want to make? inner cooled or non?
Sounds like a good setup, other than I would personally use a boost referenced mechanical pump instead. Good ignition/boost retard, arp main studs and a girdle, good heads, head studs, and then put the power to it. A 351 block with the proper support will hold 700hp pretty easily with a turbocharger. Turbomustangs is definitely the leader in blowthrough carb tech though...
After a closer inspection its looking like a stock crank with a cheap eagle I beam rod... No clue on pistons... Seems you can't believe anyone these days... I will buying these components over this winter... It's a street/strip car probably around the 700-800 hp mark
What size is the bore? I've got a set of .30 or 40 over 351w forged 9:1 turbo pistons sitting in storage if you're interested.
Mines supposed to be 040... What kinda price?
