U bolts
mommucked
Endeavoring to persevere
Rural Apex n.c.
Is it possible or safe to re-use/torque axle ubolts assuming I can unbolt them? These were made at a heavy truck shop for my Toyota w rear 3" lift blocks.
They aren't all that expensive just replace em and call it a day
I know I'm not the only one who's reused U-bolts. Sometimes have to file the edges if you cut them shorter or even run a tap/die over the nuts/bolts.
I'm spayed them w Aero Kroil and I'll see how bad I want to loosen/tighten them w 1/2' ratchet :rolleyes: . I'm gonna try to loosen, remove old blocks and replace w shorter ones. Plenty of threads for that.
I've re-used them. Biggest problem I've had is that they tend to be too rusted & seized, and something ends up breaking or having to be cut off.
