what is the max a 1310 can run continuous? I am at 16-17 degrees on a front 2 joint driveshaft with no CV. Is this going to be too steep or should I go HP front?
That's pretty steep for a running angle. What kind of angle to you get what full droop? Can you cut and rotate your knuckles and run a CV at the T-case? Or, run a double-CV driveshaft and not worry about it.
