Unbelievable Pricing On Heim Joint Kits from Barnes 4WD!
Barnes 4wd
Etowah NC
Our heim joint kits come with everything that you need for one control arm end at an unbelievable price! Each kit comes with one heat treated chromoly heim, jam nut, tube insert and two high misalignment spacers. Check out the prices below, and click on the links for more info. You wont find better prices on a quality rod end anywhere:​
Heat Treated Chromoly 1.25" Rod End Kit - $50.24
Heat Treated Chromoly 7/8" Rod End Kit - $26.74
Heat Treated Chromoly 3/4" Rod End Kit - $21.34
Heat Treated Chromoly 5/8" Rod End Kit - $16.86
We also carry square tube heim joint kits:
Heat Treated Chromoly 1.25" Square Tube Rod End Kit - $55.10
Heat Treated Chromoly 7/8" Square Tube Rod End Kit - $32.92
Our Heim Joint Kits are always in stock! If you have any questions about an order, or can't find what you are looking for, let us know. Call us at (828) 551-7616 or email sales@barnes4wd.com with all your questions.
Each kit comes with the following:
  • Heat-treated chromoly Heim joint
  • Weld in tube insert
  • Jam nut
  • 2 High Misalignment Spacers
Heim Joint Installation & Sizing Tips:
  • 3/4” heims: These heims are great for steering and upper links on lighter weight rigs.
  • 7/8” heims: These heims can be used for steering applications with a 3/4” bore. They are also great for upper links on medium to large rigs and can be used as lowers on lightweight rigs.
  • 1 1/4” heims: These are most commonly found on lower links on rigs of all sizes. They’re strong and wear slower than smaller heims due to increased surface area on the liner. They can also be used on upper links, offering much longer service life in that application.
  • When installing a heim joint, it is best to use anti-seize lubricant on both the threads and high misalignment spacers. This will allow for easier maintenance and adjustment down the road.
If you’re looking to swap out your suspension with a link system, check out Barnes’ line of 3 link suspension kits and 4 link suspension kits. You might also be interested in:
We keep our Heim Joints in stock, check them all out here.
  • Jam nut
