Barnes 4wd
- Aug 6, 2007
- Etowah NC
Universal Steering Column Bracket
Mounting a steering column in a tube chassis or a full bodied rig with a cage after the addition of full hydraulic steering can be a challenge, often times the factory column is no longer used. We here at Barnes 4wd have a simple solution; our universal steering column mounting bracket, this bracket is designed to be used with our 3/4" x 3/4" heim joints and our 3/4" jam nuts. It is manufactured from 1/8" steel, it can be welded to any size tubing from 1.5"-2" O.D., and has 5 separate mounting locations for a heim joint. These are sold individually, heim joint and jam nuts in picture not included.
Click Here to View our Universal Steering Column Bracket
