- Mar 24, 2005
- Stanley, NC
With the tire on the ground, you should be able to isolate it by turning the pinion and watching the u-joints. I doubt the drive splines on the wheel hub are worn enough to matter, and if you've replaced the hub with a drive slug, that would eliminate any wear in the sliding ring of a locking hub. So that would leave either end of the axle shaft at the spline engagement points, or the u-joints, or possibly something in the carrier or locker.you might be on to something Matt...mine is welded so there's 0 play there. but since I built this thing a year ago, tires off the ground, hubs locked in (both spin same direction and locked in) when I turned the wheels back and forth I've always had like "lots" of play from one direction to the other. Like rotate forward, stop, and when rotating backward the tire would move like "a lot" before it would engage the axles to spin everything in reverse. (hope that made sense) so now you're basically saying these hubs have been "severely" worn since day 1 lol.
I'm just trying to learn this play I've always seen in my front end rotation/engagement
