USA Made D60 & D44 Stub Shafts
Cperry
Durham, NC
East Coast Gear Supply is proud to announce a generous supply of AMERICAN MADE!!!!!!! Dana 60 and Dana 44 stub Shafts
**4340 USA Chromoly
**Induction Heat Treat
**Rolled Splines
**Proven Yoke Design and Machining to eliminate stress risers
**Lifetime Warranty
DANA 60
http://eastcoastgearsupply.com/i-12...ly-dana-60-gm-35-spline-outer-stub-shaft.html
http://eastcoastgearsupply.com/i-14...-dana-60-ford-35-spline-outer-stub-shaft.html
DANA 44
http://eastcoastgearsupply.com/i-12...-dana-44-9-94-19-spline-outer-stub-shaft.html
http://eastcoastgearsupply.com/i-14...-dana-44-9-72-19-spline-outer-stub-shaft.html
Over the years we have seen countless stub shaft failures ruin the race or the weekend. Our warranty rate for Outers to Inners is 20 to 1. Therefore with cost and quality in mind ECGS has taken the steps to make readily available American Stub shafts, Non Needle bearing Ujoints and Import inners to create the best most cost effective axleshaft packages available. Upon careful testing and examination we saw very little strength difference between import inners and american inners. However the difference between the outers is very dramatic. If you are looking for the best most cost effective LIFETIME WARRANTY axleshaft package available contact us today.
Complete Dana 60 Shaft Packages with Superjoints & American Stub shafts - $1380
Complete 44 Shaft packages w/ Superjoints & American Stub Shafts- $1125
They are pretty stout though Ask
Brandon @ RIDES
and
Scott @ Metalwerks
They were part of the test bed for the 44 shafts both running 37-38's on 44 and broke multiple sets of shafts until they upgraded to this package.
Do you have a set of the lifetime axles for a 99-04 super duty axle?
