JThomas
- Jun 22, 2006
- Summerfield
I only run half of them, but I torque them twice as tight as specs call for
then you run em' up and down the boulevardi just crank up some journey real loud and stare at my lugnuts til they tighten themselves out of fear!
That is beautiful...I only run half of them, but I torque them twice as tight as specs call for
true it will change the torque characteristics, BUT so does an extension... And the other thing is you better believe the corrosion on a stud will also change the torque characteristic. so it's a necessary evil (if that's how you view anti-seize), but in my mind it's a MUCH better option then having seized lug-nuts/any other bolt on a vehicle. And maybe most of this is coming from living in Ohio for 17 years where the salt on the road will rust stainless steel in one season and now living right next to the beach where salt is everywhere.I've also heard that anti-seize changes the torque characteristics when tightening things, but alot of this talk is like the "Which oil do you use" threads... If it works for you, and your wheels don't fall off, then more power to you.
x2I torque mine using antiseize also.
what part are you disagreeing with?Negative.
I will agree that anti seize does not change the torque, however I would contest if you are saying that an extension does not change torque reading....
metallurgy and deflection being what they are it pretty much guaranteed.
The extension will not change the torque reading, but the way you use it could. Torque transmitted is torque transmitted. The extension may flex/twist, but it will still transmit the torque. If you push down on a spring with 1000lbs of force, the spring will compress, but the scale will still read 1000lbs of force. This all changes with dynamic forces, but static or very low rate forces are not affected by rigidity.
What an extension does change is the angle that the force is applied to the bolt. A socket directly on the ratchet has very little shear (leverage in the direction you are pushing) force, and a majority twisting force. Adding an extension increases the leverage on the bolt or stud. Imagine using a 10ft extension and a ratchet. If you didn't put one hand on the head of the ratchet, you would basically just be leveraging the bolt, and not doing much twisting due to the length of the lever (extension). The effect is much less dramatic with a 1ft extension, but still present.
The important thing is that a torque wrench measures the twisting force, so you will be getting that much torque on the bolt. However, with the extension adding leverage, it does put a higher friction load on the bolt, giving you less tightness with the same "torque" reading, because you are fighting friction and metal compression, not just metal compression.
Does that make sense to anyone else?
Just to clarify everything here, I was talking about using a torque wrench with or without an extension. An impact gun gets into dynamic forces, which changes everything and makes the math a lot more complicated.this all makes perfect sense and in a vacuum is accurate.
For a steady applied force it's even practically accurate.
However when using an impact the impact does not apply constant force it is a on-off-on-off force.
As a result at rest the lugnut is still, the socket is still, the extension is still, and the driver is still.
The moment a force is applied a finite amount of torque is introduced. That torque is transmitted from the impact to the extension to the socket to the lugnut. The law of inertia says the torque will be passed to the least resistive object (I.E. the loose lugnut) Once that lugnut reaches a certain tightness it becomes easier to deflect or twist the extension than to turn the lug nut.
Now if this was a steady force the extension would store this twist like a spring and and apply it to the lug or shear the exteension. However since it is an on-off-on-off force the extension twists when the force is taken away (the off cycle of the impact) the extension can untwist back into the impact. You develop a mechanical wave harmonic along the extension and the base force level is never exceeded.
this is the principal that torque bars work on in shops. I remember the shop I worked at in college going to torque bars and the rep coming in and doing a training session on them. They used a reverse torque wrench to demonstrate that the torque value was not exceeded. They stepped up to a 3/4 impact at 150 psi and it never eclipsed 85ft lbs. They took the same extension and socket and put a breaker bar on it and ran it up to 125 ft lbs fairly easily. In a final neat and destructive test they upped the psi to 300 on the 3/4 impact we all were moved away the guy was full armor suited and the torque bar exploded...using the same reverse torque wrench they again tested and ill be damned 88ft lb...That was when I began believing in the damn things.
