Cperry
- Apr 24, 2005
- Durham, NC
Have some used/ blem specials...
Qty 3 Dana 60 - 35 spline Ford Chromo outer blems for $65 a piece still has lifetime warranty for breakage.
Used For 9"3rd member 31 spline, 4.56 gears assembled not by us $175
Ford 9" 35 spline spool (fits 3.25 Case) Used w/ good carrier bearings $65
Dana 60 Spartan locker 35 spline - used was in front application with little to no use. $230
TV6-488 gears Used appears good shape $65 can be installed in 4cyl w/ correct bearings
T8-456 Used good shape $65
Toy 4cyl 529 Diff w/ ARB $375. Seal housing Damaged and needs replacing, Gears look okay, ARB has witness marks from pinion hitting it at some point. Est. for us to fix up with new bearings, seals and ARB parts is around $350. This is an older model ARB. And diff would come with no warranty.
