i'm referring to wheel bearings
Everything in the 3rd is new
Measured pinion angle, from flange to driveshaft is right about 76 deg, making bend 14 deg. It is very close to the same at the top, frame is in the way of seeing it straight on from the side but it's w/in 2 deg or so.
Now only lift is from springs, stock shackles. When I put these springs on, I used no shim. I had some 4 deg shims on hand from earlier so I slipped those on, they're on now. I'd try going back down to say 2 deg if I could find some that small.
Chase setup the 3rd completely, I just put it into the axle. Pretty hard to screw up that part?
