Vibration on 35s
borkap
Member
Cornelius, NC
I am new to having an offroad rig. I bought a jeep with 35's on it and when you drive it at highway speeds there is a vibration to it like the tires may be out of balance. Is this just the way it is or do I need to get them balanced? Its not terrible more annoying than anything and I want to make sure I'm not gonna damage or prematurely wear out anything.
Also check universal joints or pinion bearing also had a wrangler thought was tire out on rear but was pinion bearing would only vibrate around 35 and above.
Its an 05 wrangler unlimited Rubicon. The tires are Goodyear wranglers I think and they are 35s.
How do I check to see if mine is out of whack?
it could be tires or something in driveline. double check drive shaft universals, yoke on rearend, and check balance on tires. if that is not it could also have driveshaft out of balance.
how much lift & what kind of lift & does it have ajustable rear arms & does it have a rear cv drive shaft
is the rear pinion angle set right post up some pics of the rear drive shaft & trans skid
