I hope someone will have some insight to this. It is driving me insane. I have an 04 tj. I did a re-gear to 4.88 with a detroit locker. I also have a JB conversions SSYE and a tom woods driveshaft.
I have a vibration that feels very pronounced near 70 mph, which suck because well highway driving. It lessens dramatically after 75. If I put the transfer case in 4hi and pull the rear driveshaft it completely goes away. Basically just driving in front wheel drive.(the front is re-geared also with 4.88) Would this indicate it is just a driveshaft issue or could it still be the rear end gearing being off since it is not being driven, just coasting? Would it make that much difference? I aligned the driveshaft as was needed, but I have recently read about some issues with Tom Woods driveshafts having vibrations around 55. So is this just a driveshaft issue or could it still be in a bad re-gear? Money is tight now so don't want to rebuild the rear end and still have the vibration. Any wisdom that you can impart will be greatly appreciated. Thank you so much in advance.
